I have a M&K Volkswoofer I bought in 1978. It was one of the first powered subwoofers on the market.The driver is in good shape, but the amp is blown. I would like to keep it vintage and have been looking on e-BAY, but nothing has shown up.
The driver has two 4 ohm coils. It is in good shape, I had the foam surround replace 15 years ago. Sounds good if you power it directly. I also measured voltage on the power supply output wires. The amp is some kind of oversized IC maybe, providing output seperatly to each of the voice coils. As I rememeber it, the amp output was about 70 watts.
The one thing I have seen is MCM Audio Select 100 Watt Subwoofer Amplifier Module | 50-6272 (506272) | MCM Audio Select It is a 100 watt plate amp. It has a single output. I assume that I can wire the two voice coils in series and connect it to the single output. + to - to + to -.
Can anyone suggest other replacements?
