Getting ready to recap 30's car radio for someone. I realize you can replace old paper types with modern poly
but is it spec for spec or should I go up in voltage to be safe since poly type can short?
So it would be advisable to do so?
I did run into a problem replacing electrolytics on tubes one time-I think type I used were not high enough current.
I will try srague 715p. So if circuit put out 50v you should use 100v lytic?
