Need help with Soundstream Van Gogh VGA800.2 amp
I bought this amplifier to try to repair it, since it is supposed to be a very good amp. Opened it up when I got it and this is what I found:
Pictures:
Soundstream Van Gogh VGA800 2 pictures by jaimegmr - Photobucket
It looks like someone has opened it up before to try to repair it. The 8 transistors on the bottom of the main board appear to have orange-colored hardened flux or something on the pins.
The two obvious problems that I see with the board are the following:
  • The largest inductor (L9) has one of the wires broken off where it goes into the board.
  • The board is darkened in an area that has DZ53, DZ54, R27, R28, and R30. They all got hot when I powered up the amplifier.
Is the easiest solution for L9 to just wind up a new wire to replace the broken one?
What could be causing the diodes and resistors I described above to heat up?
I checked the LEDs when I powered it up and the Rail+ and the Power LEDs were turned on. The first time I made L9 touch the broken wire while the amp was ON. The second time that I powered up the amp after holding the L9 inductor in place, only the Power LED turned on.
Is there a service manual or schematics available for this amp (or any of the Van Gogh series)?
Thanks in advance.
The largest inductor is part of the power supply, it has one winding for each rail (positive and negative). When one lead becomes broken one of the supply rails becomes missing. This may produce further damage, such as overheating of components in the output stage, because when one rail is missing high currents may flow where they are not supposed to.
So first step is to repair the big inductor and check that both supply rails are in place. Then you can check for further damage.
I connected the big inductor back in place by unwinding 1 turn from each of the two loops, so now they each have 26 turns instead of 27. The amp powers up and I got the following measurements:
GND to 1st coil of L9: -32.5V (first try), -47V (second try)
GND to 2nd coil of L9: 70V (first try), 52V (second try)
Approximately 100V across both coils.
Remote wire not connected: Power supply voltage 11.1V.
Remote wire connected (Amp ON): Power supply voltage 11.9V.
DZ53: 37.4V across zener diode, 38.3V after ~10-15 seconds.
DZ54: 37V across zener diode, 39V after ~10-15 seconds.
I measured different voltages at L9 each of the two times I tested it. The only thing that happened in between was that my power supply fuse (5A) blew up and I put in another 5A fuse, so I dont know if this has anything to do with the reason the voltages changed. The voltage across the two coils of L9 did seem to stay at around 100V both times.
I also noticed that the voltage at the input of the Amp was lower (11.1V) when the amp was off, than when the amp was on (11.9V). I did not check the currents, but this would lead me to believe that there is a higher current draw while off than when on with no signal input.
The voltage across the two 36V Zener diodes, DZ53 and DZ54, increased slowly. The longer I kept the amplifier on, the higher the voltage across the diodes went. It started out at around 37.4V for DZ53 and ended up at about 38.4V after around 10-15 seconds. For the DZ54 diode, it started out at around 37 and ended up at around 39V after 10-15 seconds.
One end of each winding on L9 has high frequency AC, resulting in non-meaningful multimeter readings (neither DC nor AC). The other end of each winding has valid DC and close to 0V AC. The "good" ends may be at opposite sides.
Zener diodes above 6V or so exhibit positive temperature coefficient, zener voltage increases more or less linearly as they heat up. Heating a 36V zener 30 deg.C can rise voltage by 1V.
You should measure amplifier current consumption with a multimeter, both turned on and off. Measuring a lower supply voltage when the amplifier is off is quite strange.
I measured the gauge of the original magnet wire with a wire stripping tool and ordered what I thought was the correct gauge (18 AWG) to rewind L9. The magnet wire I received is much smaller than what was on there so apparently I messed up on the measurement. It looks like I need 16 gauge magnet wire instead.
Would you happen to know what the original wire gauge is? (If it is a commonly used wire gauge or something.)
Unfortunately I do not have one. I've been meaning to get one for a while. I guess now is the time to buy one.
The wire I received is about 1mm in diameter and matches the AWG charts I've seen (1.02362mm). The one on the amp is just over 1mm, so I'm guessing it is 16AWG which is 1.29032 mm.
Did some snooping of the transistors near the burn area and here are the results:
Q108, TIP41C, Forward Bias: B-C 0.556V, B-E 0.571V
Q108, TIP41C, Reverse Bias: B-C starts at 1.5V, goes to O.L.
Q108, TIP41C, Reverse Bias: B-E constant 1.383V
Q109, TIP42C, Forward Bias: B-C 0.555V, B-E 0.561V
Q109, TIP42C, Reverse Bias: B-C starts 1.5V, then O.L.
Q109, TIP42C, Reverse Bias: B-E 1.393V
Q208, TIP41C, Forward Bias: B-C 0.556V, B-E 0.571V
Q208, TIP41C, Reverse Bias: B-C starts at 1.4V, then goes to O.L.
Q208, TIP41C, Reverse Bias: B-E constant 1.392V
Q209, TIP42C, Forward Bias: B-C 0.556V, B-E 0.563V
Q209, TIP42C, Reverse Bias: B-C starts 1.4V, then O.L.
Q209, TIP42C, Reverse Bias: B-E 1.401V
I left the amp On for a few minutes and the whole row of transistors (Q108,Q109,Q208,Q209) and everything between them got hot. The components near the blackened part of the board also got hot.
I also checked the AC voltage at the speaker output and got about 2.6V for the Right channel and 8.8V for the Left channel. Bridged voltage is 14V.
I also found out I have a very low-quality multimeter. It read a different voltage when measuring the speaker connection with the multimeter leads reversed.
Also read 57mV DC offset at the Right speaker connector and 0.6mV offset at the Left speaker connector, but take this with a grain of salt due to the weirdness of the multimeter.
I heated up the thermistors and the idle current stayed at 1.73A the whole time. Not sure why its giving me 1.73A now and it gave me 2.3A before.
Here are the voltages across the resistors (from resistor closest to the side of the board to the center) (I checked the voltage with the DMM leads reversed too):
Resistor ----Voltage (mV)-----Reversed Lead Voltage (mV)
R282: 0.5 -0.4
R182: -1.3 1.5
R284: 0.7 -0.6
R184: -1.3 1.5
R288: 0.4 -0.3
R188: -0.9 1.1
R289: 0.6 -0.5
R283: -0.4 0.6
R189: -0.9 1.0
R285: -0.4 0.6
R191: 1.2 -1.1
R290: -0.4 0.6
R190: 1.1 -1.0
R291: -0.5 0.6
R185: 1.3 -1.2
R183: 1.4 -1.2
Speaker Output Measurements
Right Channel: 51.7mV DC
Left Channel: -2mV DC
The Left channel was producing somewhat clean sound (as clean as I could hear on a small bad quality speaker) until I managed to short one of the two Left speaker connectors to the chassis. I think it was the Left "+" which is also the Right "-" connector. :( Now I have another problem. I hear a constant whine that changes pitch constantly. What did I blow up now?
Unfortunately I did not get to try out the Right channel before this happened but right now I am barely able to hear the music coming from the Right channel while it is very loud on the Left channel. The ebay description did say that the sound was very low, so this is probably what the seller was referring to.
