Hi everybody,
I just downloaded Boxport design, but I just can't get it to work properly.
Everytime I try to enter the T/S parameters, the software resets them to 0,0.
Is there any special way to enter new chassis-parameters?
Thanks in advance
Cheers
Holger
Thanks in advance
Cheers
Holger
Sample_850119CSC.bpd
Open the Peerless sample file that comes with the software. Key in the new T/S parameters and you will be able to save new file.
Boxport is still not working
thanks for the reply.
Unfortunalety you trick isn't working.
As soon as I have loaded the peerless file, the T/S parameters
still get resetted to 0.0.
I can't even get the peerless file working.
Couls there be a bug in the examole file, or the 2.0 Boxport version?
Cheers
Holger
Cheers
Holger
Hi Holger
You can try to download Box-Port2 at the designer's site.
The Peerless sample file looks like this:
Cone Dia and Sd are not required. The remaining fields can be entered.
BTW I'm running on Win98SE. Don't know whether it will work on other versions.
