I am wiring up a PP EL84 based upon JB's posted circuit. I am also trying to integrate a bias adjustment for the EL84's based on the one at DIYParadise HERE
I have a Bournes multiturn 500 ohm pot that I can not figure out how to wire it.
I came out of the cathode pins with a 1.2 ohm and then the 15ohm connecting the 1.2 ohm to be placed in parallel with the pot.
The pot is like this...
1.........2..........3
Which two get the cathode connections and which one goes to the shared cathode resistor or CCS if I choose to do that?
TIA
TIA
