Need Help - RF1200.2 Repair
So the bottom part of the "clamp" for the left channel speaker output is not there. RF is sending me a replacement speaker terminal. I've taken the amplifier apart and getting the block off doesn't seem that bad, it's getting the MOSFETs off without damage that looks as if it's going to be the problem.
My question, in examining the speaker terminal, is does it come apart? As can it be seperated into two pieces (1. The piece that solders to the board and 2. the piece with the terminals)?
It appears that is has a "seam."
Thank you.
