I have a power supply that I would like to rebuild, not redesign. It's a simple one that I feel can be improved with replacing some or all the parts using the same PC board. This is a 24VDC output supply at 500ma. These are the parts:
LM317T regulator
(5) 1N4002 diodes
(1) 120 ohm resistor
(2) 2.2K ohm resistors
(1) 2200uf/50V cap
(1) 47uf/50V cap
(1) 10uf/50V cap
(4) #103 ceramic caps
(1) Transformer that measures 30VAC at secondary. The primary and secondary of the transformer have only 2 wires at each end.
Whoever originally built this was very sloppy. The circuit board has flux all over it and really needs to be cleaned up,and a lot of bad solder joints as well.
I don't have a schematic, so I was wondering if I could possibly use some better quality parts.
LM317T regulator
(5) 1N4002 diodes
(1) 2200uf/50V cap
(1) 47uf/50V cap
(1) 10uf/50V cap
