You will need to know the dc resistance of the choke, too.
Rayma's advice is good. Breadboard it and use a power resistor for a dummy load which will draw the current your device will draw.
Two points, though:
Where is your bleeder resistor? You Need to have one. Its job is to discharge the filter caps so they don't hold high voltage and discharge through your body. It goes on the B+ line, after the last cap.
What's that cap doing across the switch? That's a leakage path, and will somewhat energized the transformer at all times. With the snubber (marked NL), which is a very good idea, you do not need anything else.
Good luck with your project!
