I'm making a PCB for a preamp with 5719 submin triodes and stumbled upon something very minor. The tube is a triode with 8 pins/legs. A couple of them are non-connected and probably made for a better support only.
The question is - when I solder them, should they remain non connected or sould I tie them to a ground?
What i see inside the tube is that those NC pins go to the first (lower) supporting disk (mica?) and end there.
5719 Sylvania datasheet
