I've recently repaired a Nakamichi OMS4 unit and had success but with one nagging issue.
After rebuilding the power supply section (plagued by the deadly glue), removing all the glue from the circuit boards elsewhere, replacing the pickup with a new one, and aligning the unit, it plays perfectly but has very audible servo noise emanating from the pickup mechanism.
I do notice a variation in servo noise with tracking gain adjustment but when set around the specification the pickup is quite audible.
I wanted to know if there are any suggestions or recommended checks I should do for this. I'm wondering if I should be looking for problems with the servo electronics or possibly an issue with the damping of the mechanism itself.
Any help would be highly appreciated.
