Hello.
NAD C370 integrated amplifier.
Power on only green led on front panel.
But Amplifier not work.
No Relay click.
No red or amber led...only green.
I replaced all caps on protect board,no results.
No Relay click.
Have you got +5 volts on pin 1 of CZ706? That voltage should be there as long as the unit is plugged in
Suspiciously low. Output from the 7805 regulator (IC701) should be closer to 5.6 V. Please check input voltage across C707/708. If at least 7.5 V or so, I'd supsect a bad regulator.+4.3v on pin 1of CZ706
There is a +12V output jack (3.5 mm or 6.35 mm stereo jack) as well, please check what's coming out of there.
- NAD C370 problem
