My work system for work has been:
HiFiMeDiy Sabre USB DAC 2 w/ external PSU
LittleDot Mk. III valve amp
Sennheiser HD 595
2 x Fancy phono cables.
Banned because:
Not PAT tested, refusing to PAT test it themselves or accept external PAT testing.
Not required for work.
So, I need to replace everything but the headphones (I'm allowed those) and still have a decent sound.
Therefore I need:
A new DAC
A new amp
Would quite like:
Recommendation for a pair of closed back 'phones.
With the following requirements:
1) Discreet.
2) Not mains powered in any way, the only external power it will be allowed to use is USB power.
3) Easy on the ears (I had a pocket IC amp, it was too harsh, I couldn't listen to it for more than a few hours before my ears got tired, I little dot I could listen to continuously)
Any suggestions welcomed.
Many Thanks,
J1M.
Sennheiser HD 595
Banned because:
Therefore I need:
A new DAC
A new amp
Would quite like:
1) Discreet.
Many Thanks,
J1M.
UCA202 sounds pretty decent on headphones with >60ohm impedance. All USB and measures pretty well according test by Nwavguy (O2 designer).
NwAvGuy: Behringer UCA202 Review
Doesn't cost much so might be worth a listen.
No one knows I am using a JLH class A headphone amp at work.
For those of us who are not where you are, what is "PAT testing" and why in the world is it "required" for something to come into your office??
It's a euro-nanny state thing: PAT (Portable appliance testing) - HSE's answers to popular questions
Maybe my little dac1101....
~£443, quite pricey.
Also looking at Oppo HA-2. (£250)
Somebody has also mentioned the Behringer UCA202 (£23?!?!)
And just found the BEHRINGER UM2 U-Phoria Audiophile 2x2 USB Audio Interface (£33?!?!)
Lots to read, thanks, I'll leave this thread up if nobody minds.
J1M.
Er, I'm terribly sorry but I appear to have posted this to completely the wrong website by accident.
How do I delete a thread??
I've just moved this to everything else.
Did you mean wrong forum or
?wrong website
Say what????
To quote from the above site:
"Is Portable Appliance Testing (PAT) compulsory?
No. The law simply requires an employer to ensure that their electrical equipment is maintained in order to prevent danger. It does not say how this should be done or how often. Employers should take a risk-based approach, considering the type of equipment and what it is being used for. If it is used regularly and moved a lot e.g. a floor cleaner or a kettle, testing (along with visual checks) can be an important part of an effective maintenance regime giving employers confidence that they are doing what is necessary to help them meet their legal duties. HSE provides guidance on how to maintain equipment including the use of PAT."
Huh??
Does not seem to be any rational basis for excluding your tube gear - perhaps it needs to be enclosed so that the tubes can not be touched?? Or tube shields used.
Maybe that will satisfy whomever really is out to give you personally a hard time. Because that is what it sounds like, unless they've gone around and told all sorts of people that they have to take stuff out?
I'd sue the crap out of them...
Huh??
PAT testing is NOT required by law.
I recently spoke to a PAT testing company who said that the number of companies requiring equipment to be PAT tested was dropping dramatically.
It seemed to be a passing fad.
Andy
Andy
It's getting a little long in the tooth but the FiiO E18 Kunlun has been part of the work kit for a while. Tops out at 96 kHz so no drivers required with Windows, has a line input and also works as a portable battery for USB devices. Its very low output impedance works much better than the headphone out on my ThinkPad.
RoboJ1M, it isn't any of my business, but shouldn't you be 'working' at work, after all, they pay you for working, not listening to music, right?
It's a HUMAN RIGHT don't you know
+1, though the common practice of forcing employee's to listen to BBC Radio 1 should be banned as a violation of human rights.......
Not sure if this is serious or tongue-in-cheek, but remember that some of us have desk jobs in crowded offices that can easily be accompanied by music
/U.
- General Interest
- Everything Else
- My valve amp has been banned from work.
