My tweeters are too loud!!
With no good information to go on, Cals' recommendations are a good starting point. Otherwise we need more to go on, that's why I asked if you could measure them. Typically the DC resistance will be aouund 75-90% of the nominal impedance, once that is known, we can give you better suggestions about what to try.
Mike
Mike
I can measure them at my shop, so I will tomorrow! In the meantime, however, is there a set of standard audio grade resistors that I can buy to try out different things?
And also, where are you all getting those numbers for the capacitor!?
OK, here's what I'm thinking; acording to the "specs" published on the E-pay site the speaker drivers response extends to 18kHz, but probably more like 15kHz in reality. If the tweeter is nominally 4ohms, the 3.3uF cap gives a roll off frequency around 12kHz, and the 2.2uF cap would put it around 18kHz except that the tweeter voice coil inductance will give rising impedance with increasing frequency, so a good guess would be an actual roll off around 15kHz or so. And yeah, that's alot of guess work, but with nothing more to go on, it's about the best that can be done.
Mike
