My KT88 SE project
Hi all:
It is up and runing, so I thought I would share this project with you all.
It is a single-ended KT88 in Triode mode, with a 6DJ8 SRPP driver stage, James OPTs and a HUGE power supply made from trafo and chokes rescued from some very classy radio equipment.
The whole thing is built on an open-frame chassis made from 1/2-inch (yes, thats 13mm) aluminium plate. All up it weighs about 55lbs.
Construction is very straightforward. However the power supply is a bit wierd. The Trafo outputs 375-0-375. Since I did not have room on the chassis for a rectifier tube, and SS rect. brings the voltage up so high that I would not have been able to use reasonable value caps, (plus, I had 2 chokes) I decided to split the output of the trafo into 2 seperate half-wave supplies.
The result is a seperate supply for each channel, which share a trafo secondary. So an almost doal-mono design 😉
Some more photos:
Just starting construction
Things well along
Nearly done
first power-up = measuring voltages and waiting for smoke
In the room and making tunes - mighty good-sounding, if not overly powerful.
and the schematic
The holes were all drilled. The square holes that mount the trafo and chokes were drilled at the corners, then cut with a jigsaw, then filed smooth. Very time consuming and rather mad, really.
However, the chassis is nothing if not solid 🙂
Are those Fostex TE166Es?
Those look like Dave's tweaked FE127E.
They most certainly are Dave's enABleD FE127s.
BTW: Thanks very much, gmilitano, for the KT-88 SE you published on your site. It is the source for the KT-88 section of this amp. 😉
what about cathode decoupling?
Good eyes 🙂
I left off the cathode bypass for two reasons - 1) because I wanted to get a good idea of the effect on the sound with and without a cathode cap. and 2) because the schematic calls for a 220uf cap - I don't have any 220uf of any kind of quality right noiw and the idea of putting a cheap electryolytic in there just makes me cringe.
Right now, the amp sounds fantastic. When I can get some 220uF Black Gates (or similar) the I will try them.
