Hello !
Happy new year everybody !!
I began to think about a new project but I don't find a lot of informations on the net...
- First, I want modify my actual stereo system : KEF Chorale + 2 Beyma 12BR70. I listen Classic, Jazz and Rock music.
So, I thought use these drivers :
2x Monacor SP-8/150PA
Monacor MRD-160 on a RCF H100 horn
and I would like install them in a MTM box...
I will join my new speakers with the 12BR70 at 120Hz (I use an activ xover Behringer CX2310)
- In second time, I will add surrounds speaker in the system to make a home-cinema.
Maybe I will make something like Klipsch RSxx ... with these drivers :
2x Monacor SP-6/100PA
2x Monacor MRD-160 on a B&C ME10 horn
What do you think about this config ?
I hope you will give nice technical answers 😉
@+, Olivier
@+, Olivier
You will find links of the products below :
Monacor MRD-160 :
http://www.monacor.de/en/produktseite_monacor.php?artid=4638&spr=FR&typ=u&spr=EN
Monacor SP-8/150PA :
http://www.monacor.com/fr/produktseite_monacor.php?artid=1993&spr=FR&typ=u
Monacor SP-6/100PA :
http://www.monacor.com/fr/produktseite_monacor.php?artid=1991&spr=FR&typ=u
RCF H100 horn :
http://www.rcfaudio.com/VediMacro.phtml?IDMacro=1658&m1=4&m2=0&m3=4_0_2
B&C ME10 horn :
http://www.bcspeakers.com/index.php...rizione=47&prodotto=87&id_descrizione_prod=81
Monacor MRD-160 :
RCF H100 horn :
B&C ME10 horn :
Hi Olivier,
Not many here have much experience with Monacor I think,
but your proposed system seems OK, although it's a big step from your bookshelf Chorales to what amounts to a small PA system....
Looking at the Frequency response graphs, the only problem I can see is that the MRD-160 + horn rolls off above 10KHz - OK for PA, but for Hi-Fi you might prefer drivers with a more extended HF response?
Thanks for your answer PeteMcK !
Monacor is a famous brand in Europe, they are not high in the top of range like JBL and others but they have a lot of various drivers...
And this is because you don't know them in US, Australia (and others ) that I place datasheets in a post.
😀 Oh !! YES ! I hope... This is near a PA system but I don't want a PA sound... I want something smoother 😉 .
I think it won't be a problem. Otherwise I could add a tweeter from 10Khz...
The MRD-160 need to be attenuate, so I will add a resistor in line and I think it will equalize the signal a little bit.
Olivier
Olivier
