I am looking for a good design for my first DIY speaker.
My requirements are :
moniter/bookshelf size
2 way
I could go 3 way, but I'll try and avoid it
front port
simple crossover
4-8 ohms
under $200 a pair
low cost drivers
I am going for value here.
If anyone could post a link or give suggestions it would be great!
Thanks, spacejunk
2 way
front port
simple crossover
4-8 ohms
under $200 a pair
low cost drivers
Thanks, spacejunk
Can you spring for the Zaph SR71? You can get it at Madisound as a kit with pre-built crossovers and no cabinets for ~$330 + S/H. From what I've read it is a phenomenal loudspeaker and can compete with commercial speakers in very high price categories.
spacejunk said:
Thanks for the reply. Those look good but I think I want drivers that are a little better...
And what do you think is the problem with Zaph's driver selection ?
good drivers ? : http://www.madisound.com/catalog/product_info.php?products_id=1731
as used in : http://www.stereophile.com/loudspeakerreviews/104meadowlark/index.html
http://www.geocities.com/woove99/Spkrbldg/RS180_2way/RS180_2way.htm
Above might come in around the budget. the Metal tweeter
version has a simpler crossover, very high bang for the buck.
Though I suspect the best BFB if a subwoofer is not used in the
floorstanding version of the BAMTM, a lot of speaker for $200.
http://www.zaphaudio.com/BAMTM.html
/sreten.
- My first DIY speaker
