You don't say what op amp it had before or provide a link to the schematics. A lot of times when you put in a faster op amp than a 741 or a 4558, oscillation occurs. This happened on my disco mixer at 1 Mhz. It didn't cause my CS800S amp to motorboat, but it sure ran the cooling fan really hard. You might try putting xx pf (picofarads) of capacitance around the feedback resistor on the op amp. This cuts the gain of the circuit at high frequencies. I used disks marked 22 from a R**** S****** grab bag, probably about 22 pf, and probably mismarked, knowing R**** S******. No more oscillation.
The feedback resistor is the one that runs from the point of the op amp (output) to the minus input.
You might also put in a shorting jack on the input of the amp if it is 1/4 phone or mini phone jack. This shorts the input when the source plug is not attached and prevents picking up RF from from the PC or TV in your room, etc.
