hi, i bought a Musical fidelity b1 from ebay and it sounds very good, i only confused about one of the source named CDV, anyone know what is this? thanks..
http://hifiview.com/
abiedoodles said:hi, i bought a Musical fidelity b1 from ebay and it sounds very good, i only confused about one of the source named CDV, anyone know what is this? thanks..
probably CD(or)Video
there are phono,tuner,CD, tape
im thinking of CD video, this amp made around 89' to 90', i dont know if there is a CD video or VCD at that time maybe laser disk.
hi, im planning to change the 4pcs 4700uf power capacitor of this amp as it looks old and bulging, for the MF b1 owner out there, any other modification you can suggest to boost the performance of this amp.... thanks in advance
There is a site for an mhennesy where he has taken a Musical Fielity A1 apart to upgrade it. The A1 was a class A amp, but if you intend to improve the power spply there may be info on here.
The link is :-
http://www.mhennessy1.f9.co.uk/mf_al/others.htm
The link is :-
thanks for the links,
a1 is different design they change the preamp as it is always the problem with that amp.
- Musical fidelity b1
