Just bought one of these amps off eBay similar to this thread
http://www.diyaudio.com/forums/tubes-valves/125631-meng-series-el34b-integrated-amplifier.html
However my problem is not a hiss or a channel not working, my issue is the fact that it doesn't appear to be turning on. When I flick the switch, the tubes do not respond whatsoever, they don't heat up, they don't light up, they just stay cold and lifeless. The gorgeous Triangle Zerius speakers I bought that I hooked up into the amp produce no sound connected to my CD player.
I replaced the three pronged power cord with an old one that I know for a fact works, because it used to work with my old computer. I made sure before I even plugged it in that the power matched the output.
I really am a newbie here, and I have contacted the friendly sellers from eBay and hopefully they'll get back to me soon, but if anyone has any suggestions, like taking out the tubes and putting them back in again, or opening up the device and tinkering around in there, please let me know
Here's a link to the specific amp btw
MINI L3 EL34 x 4 Push Pull Tube Integrater Amplifier ch | eBay
Check the fuse first. It is integrated in the 3-pin power socket.
If the fuse is OK, the next step is to open it up and check or any loose wires/connections.
SveinB
SveinB
SveinB
Where is the fuse located? And do I have to unscrew anything to check on it?
Nevermind, fuse is fine, but I'm still opening up a claim on eBay to get a full refund. It's not worth all of this hassle
