I intend to build a 3-way speaker with multiple drivers in each range.
Coupling of the drivers in order to achive the desired impedance load, will, in the bass section, lead to 3 drivers in series and one in paralell (tot. 4 drivers, all identical) ie. asymetrically grouped.
With a nom. impedance of each driver = 8 ohm, the bass system imp. load will be 6 ohm.
My questions is:
Will each of the four drivers play equally loud, and if so, is there a formular to calculate increase in sensitivity as a result of a 2 ohm lower imp.
My questions is:
