#1:
You shouldn't need to change the value but you should check it to confirm that there is no increase in current draw at full duty cycle.
#2:
This amp isn't like most amps. There is one gate resistor per bank of 3 FETs. The 47 may work but it's generally a 22 ohm resistor.
