MTX Thunder 1500DX
Does anyone have any pics of this amp ?
I need to know the values of the following components.
Q105
C174
C66
You could try MTX but I think that they've gone to the dark side.
I can't understand why manufacturers don't distribute diagrams. There isn't one competent engineer working for an amp designer that couldn't reverse engineer any design out there that doesn't use PICs. For the most part, there is nothing that can't be easily copied. The only people that withholding literature hurts is the service industry.
For the caps, start with at least 10uF and voltage above what you measure across the pads. Recheck the voltage after the cap is installed.
You can probably get a good idea of what needs to be in each location by the voltage on each leg. There was another missing one across the board.
Back to this amp .
I have a question hopefully someone could answer .
There is 1 transistor missing and could be one of the following MPSA42,56,06
The emitter of the transistor connects to the base of an mpsa42
The base connects to the emitter of an mpsa56
And the emitter connects to the outer legs of the rectifiers .
Does anyone have an idea of what transistor this might be out of the ones listed ?
The 3rd leg of the transistor in question connects to the stripped side of a diode then to legs 1-3 of the rectifier
Sorry it would be the collector that connects to the outer legs of the rectifier .
So wondering which transistor I should use
