Hello,
I have an MTX TA81001, at this moment there are two parts defective.
The locations from the parts are Q405 and Q401.
I want to know the part number, the values of these parts and the alternate parts.
Thank you.
Thank you.
Q405 is likely marked 6P or C1 which is an MMBFJ111 or SST111 (equivalent parts).
Q401 is marked 1D and is an MMBTA42.
The JFET isn't likely defective. They read about 10 ohms from drain to source out of the circuit.
The Q401 Marked as 1DZ is defective for sure.
The Q405 Marked as C1URA is defective also (The base and emitter contact each other constant).
It broke the two A3120 Chips at location U403 and U402
Thank you for your reply before Perry Babin, are you sure those are the equivalent parts?
The C1 transistor is a JFET and will read approximately 10 ohms out of the circuit between drain and source. Look up the datasheet. The two legs that you refer to as base and emitter are drain and source. The top leg is the gate.
Perry Thanks for your fast reply.
The measured results from the C1URA are:
From Drain to Source: 28 Ohm and 27 ohm (going down)
From Drain to Gate: 5,12 Ohm
From Source to Gate 5,12 Ohm
For those who are interested in the full story with pictures.
On my MTX 81001 are the following parts defective:
C406 marked as 35V 1000UF
C408 marked as 35V 1000UF
D404 marked as 1001
D405 marked as ES2D
D406 marked as ES2D
D401 marked as 831B
U402 marked as A3120
U403 marked as A3120
Q401 marked as 1DZ
Q405 marked as C1URA
The Led400 turns onn.
Also the "For Service Only" Led turn onn
D404 marked as 1001
D405 marked as ES2D
D406 marked as ES2D
D401 marked as 831B
Q401 marked as 1DZ
The part at location D401 marked as 831B is this a zener diode?
And how much volt is this diode?
What is the equavalent part fort this?
it seems that location R468 with a SMD Resistor 1000 is defective
and
location D409 Diode J5C.
Does anyone know the equivalent part for location D409 (Diode J5c)?
and
Hello,
I replaced the following locations
D405 marked as ES2D
D406 marked as ES2D
D401 marked as 831B
Q401 marked as 1DZ
R410 marked as 1001
I recently also replaced Location R468 marked as 1000 and Location D409 marked as J5C.
After replacing these parts i decided to turn onn the amplifier with a 12V 2A adapter.
So i turned onn the amplifier and after 3 seconds i saw some smoke coming up from the area with location numbers C411, D404, R410 and the chip A3120.
Does someone know why the smoke is coming.
D405 marked as ES2D
D406 marked as ES2D
D401 marked as 831B
Q401 marked as 1DZ
R410 marked as 1001
The A3120 above location C411 was smoking i think.
Also the Zener diode on location D404 marked as J5C is broken
D404 is the voltage reference for the opto-coupler's voltage regulator. It will have to be replaced before you can do anything else.
Also check FET401 (near the RCAs). is it shorted?
Oke im ging to replace the Opto copler.
The Fet401 marked as IRF540 is this a N Chanell Fet?
The D404 is this a J5C ? (mine is broken cant read the number)
J5 is the marking for the part number. That converts to MMSZ5250B. Contact MTX if you want confirmation.
Until you get the regulators working properly, I'd suggest pulling the two 3120s and soldering a jumper connecting pins 5, 6 and 7 on each 3120. This will prevent damage to the opto-couplers and the jumpers will keep the outputs from switching on.
Yes. Look up the datasheet for the IRF540.
Thanks, i will wait till the parts arrive.
At the location R407 i`m measuring 1.10 ohm and going up.
Is this resistor good?
IF the shorted FET is still in the circuit, you will have to remove it or the resistor to check it.
- General Interest
- Car Audio
- MTX 81001, Want to know the value of two parts
