I got this amp from a car audio place after it had been collecting dust in the back for many years. Its a MTX 4320 with the year 1997 stamped on the PCB. A 4 channel amp rated for 40x4 @4 ohms or 80x4 @2 ohms. The amp looks a bit more powerful than that by the way it is fused and the number of output transistors; however I guess powersupplies were probably not built strong enough to withstand the output's requirements. would personally like to see at least one power fet per output transistor in an amp; ratings aside. This amp has twice as many output transistors as there are power transistors. Not to say that was the cause of the issue but it could have only helped. The amp is fused for 70A.
First things first; opened her up and found several transistors shorted so I went ahead and clipped them off the PCB. FET5 and FET6 out of the 4 power FETs stamped P60N06 are shorted. FET9 and FET10 out of the 8 output transitors stamped 50N06V are shorted. I also clipped RECT2 because I thought it was shorted (FEN16CT) but it turns out it might be alright. i thought it was shorted but it checks out with diode test - I can resolder it on when I need to.
At this point I pretty much know that all the large transistors are going to need replacing, but would like to work with what is left on the board first.
I cant seem to get this amp powered on safely; the amp pops 10A fuses on the workbench when connected even with REM disconnected. Resistance across +/- quickly rises such as a capacitor being tested.
Pad for pin 1 has this output with Volts/div set to 10:
Pad for pin 2 is getting 12v +DC.
Pad for pin 3 shows nothing - reference from ground is .9 ohms.
Before running these tests I removed RECT1. I guess the way the circuit is laid out make it look like pin1 and pin3 were shorted on both RECT1 and RECT2. I'm going to put them back in.
We're playing a bit of tag here. RECT1 and RECT2 are back in and the amp powers up without the powersupply fets. The RECTs have 0vDC reading from general ground. I think the amp is getting power but the red LED is not lighting up. I think it might be blown, cause I get .35vDC across the LED.
Will IRFZ44NPBF-ND work in place of the P60N06 power supply fets? I have a dozen matching spare from the PPI amp rebuilds.
I put 4x IRFZ44NPBF-ND in FET5 through FET8 and the amp powered up! LED and all. No fuses blown. I'll run it through some tests to see how far down the rabit hole I can get. At the very least the LF channel is totally blown because the transistors were shorted; clipped off yesterday.
I see where I cant really use IRFZ44NPBF-ND in place of the P60N06.
IRFZ44NPBF-ND
-rated for 55v and 49A
P60N06
-rated for 60v and 60A
At least I can now finish troubleshooting.
IRFZ44NPBF-ND
P60N06
While I'm playing search and destroy, I noticed P60N06 runs about $5 each from Mouser.
Would this be a good alternative? They are $1.80 and rated for 150w - 30w more than the P60N06 which this amp should enjoy.
ST: P60NF06
STP60NF06 STMicroelectronics MOSFET Power
ST: P60NF06
Looks like this amp is going to be fixed. Three out of the 4 channels sound good enought for me to leave alone. I just need 4 power and 2 output transistors (LF channel blew).
Parts list:
4 x P60N06 / P60NF06 (Need confirmation that NF06 can replace N06)
2 x 50N06V
Does this power supply output look correct for this type of amplifier? Measures the same shape at pins 1 and 3 on the power FETs. One has slightly more amplitude than the other.
Parts list:
2 x 50N06V
Actually, it looks like the P60NF06 is on backorder for 5 months.
What about the P60NF06L?
STP60NF06L STMicroelectronics MOSFET Power
That looks about normal.
The FET you listed may work in this type of power supply but may not work in the more common type of power supply.
I typically use the IRF3205s in MTX amps and have never had any problems.
Digi-Key - IRF3205ZPBF-ND (Manufacturer - IRF3205ZPBF)
Good deal those are about $2 and 180w compared with the original's 120w. Should work quite nicely.
What about a replacement for MTP50N06V? It seems a hard one to find, discontinued 8 years ago. I cant find all that much info about it. If I must choose a different unit, should I replace them for all 4 channels? Only the one channel blew out.
The following transistor may work:
Digi-Key - FQP50N06-ND (Manufacturer - FQP50N06)
I actually sold it on eBay. I hope its not the same one lol.. the one I sold was working fine. All I have are pictures under this album, starting from Pic #4 through pic #15. Pic # 5, 6, & 7 may not be from the same amp though. I think it was a 4230.
PPC PC275 pictures by unclemeat2010 - Photobucket
No, this could not have been your amp, this one was in super bad shape, had about 1/16" of shop dust in it, burnt...everything... no bottom cover/sides, few of the pot shaft's are gone, needed a bath really bad... ect...
Thanks for the help, I'll start a thread for it and a few others soon.
- General Interest
- Car Audio
- MTX 4320 wants a second chance
