I am on the process of gartering parts to build one or 2 of Nelson designs
Reading trough the various posts there is quite a bit of information relating to moss fet matching and testing.
Patrick and others are doing quite a bit of work on this especially on finding less noisy Jfets
Papa Nelson wrote a couple of articles on this regard.
How to: Matching Devices Passdiy
Piratical Mos fet Testing for Audio First watt
I have started to test a batch of 10 IRFP240 and this is what I am finding out.
Test conditions
I feed 10 volts to a 10 Hom's resistor to the drain of the Moss fet
The gate is connected trough a resistor and a pot to the + 10V
The source connected to the ground.
I have a block of mild steal 25 X 50 X 100 mm a thermometer of which the tip
sit under the center Mos fet trough a hole drilled at a couple of millimeters on one corner of the Iron Block.
The Moss fet is clamped to the iron block.
Now I keep the Moss fet under a lamp just to get them settled at a bit over ambient temperature
I was running the test for about 4 to 5 minutes and then take a reading of the VGS
I have noticed that the same Mos fet was giving different results depending on the temperature.
If I run the test for longer say 10 15 minutes the temperature appears to level out at about 31C
I must have reached an equilibrium between the heat given out by the Moss fet and the heat dissipated by the iron block.
If I retest the same Moss fet at the same temperature the results are the same.
Ergo: Mossfet matching need Constant voltagge and constant temperature.
I suspect that if I make the Iron block smaller I may be able to Shorten the test time but the temperature at which it will settle will be higher.
At he momement I am taking the reading with a 4000 count multimiter and should be able to match at the second decimal place.
Test conditions
