Hi guys. Need this power supply mosfet however I can't find any online. Been discontinued by the looks.
For a taramps smart 8k bass.
Problem is I only need 1 (or 6 to replace the entire bank on the transformer. (24 total)
I'd obviously like to just replace 6 in the bank rather than all 24 to an equivalent
I don't trust aliexpress. Or ebay
Anyone have a place to get them or have 6 I can buy off u.
Will need to be shipped to Australia
Thanks 🤞
Thanks 🤞
If you're getting paid for this, pass it onto the owner.
If not, do a parametric search and narrow down the alternatives and see what's available to you.
Post what you need to know if you can't find what you need, including the supplier that's in Australia.
Just need a single 180N4F6 however as I'll never get the same batch code I'll need to swap all 6 in that bank to the same batch.
It's a brand new amplifier never seen power so I don't want to do a dodgy job on it.
Our only supplier of parts here in Australia is element14 which they show no listing for this part.
Mouser and such always charge $100+ shipping which is unviable
Ask the owner if he wants the amp repaired with inferior parts. Explain to him the problem with the expense of part shipping and the fact that it will be nearly impossible to get matched parts buying only the minimum number and the reliability issue with that alone.
What makes this your problem? In life/business, you have to make choices and the best choice here may be to let someone else be responsible for this repair.
Every tech needs a pointy stick to show problem amps back through the door.
This amp was given to me for a warranty assessment. Then they just decided to just provide the customer with a brand new one so this is mine to keep.
Was a DOA.
Along side a single dead PS mosfet there was a out of tolerance resistor that prevented remote circut being sent so after removing shorted fet I had to see why it was not turning on( as they could not provide me with schematics I had to go in blind) no issue found the problem in like 15 minutes.
Anyway this amp can't be sold. Too big for anything I need. But I'd like to properly repair it best I can.... my OCD won't let me half *** it.
Best I can let go is replace all 6 in the bank for same batch numbers.
Just be left to sit on the shelf to look at as I do get a good sence of pride repairing this stuff. Who knows may give it to a person in need one day down the track.🙂
Was a DOA.
contact Taramps. They are very helpful
https://www.taramps.com.br/en/duvidas-e-solucoes-em-produtos/
If you do warranty work for them, they should be able to supply parts and a diagram. They do it for other warranty techs.
OCD makes life... Different. I know.
Yeah normally I would but this case seems a bit wierd. I won't say much more publicly but yeah I'm just gonna get the parts myself🙂
- General Interest
- Car Audio
- Mosfet needed for smart 8k
