Mosconi AS1004
Hello!
Good day! Please give your technical opinion...
I repairing AS1004, 4 channel Mosconi Gladen. I replaced 4 x 65N06 and SG3525 PWM IC. After I replaced those parts and hook up the positive and negative power supply without the remote positive signal yet, right away the amp draws large current and mosfets becomes hot.
Anything I need to check?
There is no shorted mosfet or hanging gate terminal. I replaced the SG35235 thrice and twice for the set of Mosfets, gate resistors 75ohms and 10k pulldown resistors were also good but still no luck.
Thank you!
Are you saying that the drive signal at the gate pads (FETs out) is perfect?
Yes, prior to installation of 4 mosfets, I powered the amp and checked the drive signal at the gate pads, they are perfect square wave.
The Amp draws large current if you connect the positive supply and negative supply only. No remote turn on signal yet to amplifier ; mosfets becomes hot.
If your amp have excessive current draw connecting only negative and positive power cable (and you are sure that to gate pads there is no drive signal without remote cable) then, probably you have defective or false power mosfets.
Check also zener diodes (if there are), big resistor and capacitor which are located near the primary winding.
