Well, hell, if it's a question of settling questions, then I'll add one, should anyone have the time and energy (and a sufficient number of Zens on hand):
--To wit--try the two Zens with one input inverted, thus converting the whole contraption into a push-pull, class A amp. (Connect grounds and run the speaker from the two hot output connections.) Yes, by definition, you lose your 'single-endedness'...or do you? A nice philosophical point upon which to split hairs.
Anyway, depending on your perspective, you could easily come to look at this as a mid-point between a Zen and a Son of Zen. Call it an Illegitimate Son of Zen, so to speak. Consider the possibilities--an active current source (I)SOZ, with the efficiency increase inherent in having replaced a resistor or two.
Such a thing wouldn't be all that difficult to build from the ground up, but even so, having complete Zens on hand reduces it to a simple question of building blocks.
And speaking of feedback, if you were to connect a resistor between the two halves of the circuit, you'd have this really neat way of cancelling distortion. Oh, never mind...I'm sure if it worked, someone would have done it by now...(ahem)
Grey
