Hello since i readed much about audio lately i wondered if it would make "sense" to mod a RPi4 board for "ultimate SQ" (kinda like the allo usb signature)
things i came across so far that do "in theory" make sense:
1. replace the DC/DC Converters, one step further would be to provide the different voltages directly but i think thats a step too far, and someone also posting here said good dc/dc converter do make nearly the same effect (maybe add filter capacitors too?)
2. filter capacitors for usb, maybe as a sort of decoupling for all usb devices drawing power?
3. remove the BT/WIFI modul or disable it in some way, since even if disabled in config it still actively transmits
4. replace the clock(s) for better ones
5. remove the headphone amp circuitry and maybe other unneeded stuff?
any other ideas/suggestions?
Tim Curtis pointed out in the moode forum (where i posted this thread too) that it may be a good idea to use the CM4 + I/O board, this would make it possible to buy the cm4 without wlan/bt to begin with and has emmc on board if wanted (and in the end it costs pretty much the same as a normal rpi4b+)
i wanna focus on usb playback and the i/o board seems to have a good layout, the pcie x1 could be used for a usb 3.0 board to drive a ssd and things like wlan/bt dongle (so the usb 2.0 can be used standalone for the dac, its also a good thing i think that the usb 2.0 chip is very close to the ports)
tho im not sure about the hat performace with this kind of board (official i/o board) since it has rather long lanes/traces
i also watched around for other boards (there are quite a few) but couldnt find any that looks better than the official one, most have just too much unnessacary stuff or too few usb ports... i specially checked those ones -> https://pipci.jeffgeerling.com/boards_cm (thanks for that jeff btw
any ideas/tips are very welcome
