I am looking for a new project, I have two cartridges Denon DL110 and a Lyra Kleos. Can someone recommend a stepup transformer and/or pre amp for these ? I would not mind building something.
nattawa, what are the specs on this design ?
The board takes power from a cellphone charge cord or a 5V power bank when you don't feel like plugging in a wall outlet, then a DC-DC module steps it up to +/-24V split rail, followed by a pair of 317/337 as post regulators that clean up and step down to +/-17V for the op-amps.
...Did you use a dc-dc similar to this one or did you create your own circuit? Thank you
nattawa, on the RIAA correction amplifier, what is the expected nominal input signal amplitude ?
rayma was right. 35dB works with most MM carts. Besides, the 2nd stage of a two-stage
design works as a flat gain-block/buffer, and can be easily altered for desired gain.
I didn't bother the specssince I have no means of measuring. Was a rescue project as a friend of mine had a phono stage went dead in a receiver...
Anyways according to the app-note design objective (attached), it appears to have decent s/n. I expect better from OPA1641 as its voltage noise being on par with LM833 but absence in current noise due to the JFET input construction. The gain of the app note original design is 35dB @ 1KHz, my prototype build has it at 40dB.
P.S. frequency response against RIAA
Hi nattawa,
what capacitor did you use for C0 ?
