Dave,
It's a similar player to the Philips cd650. Try searching for that one!
http://www.diyaudio.com/forums/showthread.php?s=&threadid=60144&highlight=cd650
What's the problem with it? (I also own a Mission PCM7000)
Regards,
Ashley.
Regards,
Ashley.
Thanks....
Sometimes when you start a CD the rotation of the CD just takes off, it spins up to many many revs, way faster than it should. Pull of the cover and play with the small piggy back board between the Mission analoug board and the tray, restart a CD it plays ok for a while then spins up again.
Any ideas????
Thanks Dave
Any ideas????
Thanks Dave
Dave,
Sounds like an intermittent fault somewhere on the piggy back board at a guess. As it plays ok for a while I wonder if it might be a connection contact problem (my Mission has a corroding pcb!)
Try here also:-
http://www.diyaudio.com/forums/showthread.php?s=&threadid=57573&highlight=
Regards,
Ashley.
Try here also:-
Regards,
Ashley.
