I have a t-d amp that runs 35mA off of a very small 12v battery. Is there a way a can charge the battery while the amp is in use from a car cigarette lighter. Also how do you install a light the will come on when the battery is fully charged.
Can you split the two wire coming out of the male lighter insert having half positive going to the amp to run it and the other half of the positive connecting to a 1 ohm 10w resistor then to the small battery? Same thing with the split negative wire.
Any help would be greatly appreciated, I have caused a lot of smoke recently and I need some help.
-G
-G
