Joined 2003
a007udio said:Thanks for help.
Other drivers are:
Bass: B&C 18PS100 PA driver
Tweeter: Fountek Neo CD 3.0
I was looking Davis Acoustics 16 GKLV 6M and it looks good.
Will this driver work good in this combination?
I wount to build high sensitive speaker wich can play quite loud.
Are you aware that the 95dB bass driver will end up being roughly 89dB after baffle step has taken place?
I would say look for a 90dB mid, if you dont know what bafflestep is then I suggest you do a search on google or on these forums. I know ive posted twice describing what it is.
What about one of these 10" Seleniums?
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=264-332
Joined 2004
Good Midrange
Hi:I have used the Morel dome midrange with good success,Here is the PE link.
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=287-020
- Midrange with 92 or 95 dB
