Midrange match for XT25SC90-04??
I am looking to design a small satellite system using the XT25SC90-04 tweeter and a small 3-4" mid-woofer in a small top cab and a 8" woofer mounted in a separate cab.
I want to run the sat module down to at least 300hz if not 200hz so the midrange driver needs to be pretty wide bandwith. Most of the 3-4" drivers i have found have a low sensitivity. But the Tang Band W4-930SF looks very interesting. wide and flat from below 200hz out past 3-4khz and 89db@1w where the XT25 is 91db so I wouldn't have to pad it much. most other small drivers are at 85db or less. and there isn't room to mount a 5" driver. a 3" would be an ideal size but a 4" will just fit.
The biggest problem is that this needs to mount in a very shallow but wide area so i cant use a mid driver with a giant magnet on the back. I might be able to raise the crossover point from the woofer to the mid but i want to try and keep as much up top as possible as the woofers will most likely be placed at knee level or otherwise not in a direct plane to the ear.
any other suggestions for a small midrange driver to mate to the XT25?
