hello. does anyone know the hight of the bearing from the bottom of the plinth to the top of the bearing where the underside of platter surface rests on the gyrodec?
or if anyone has a complete bearing assembly at hand could they measure the hight from the bottom of the threads to the top surface where the platter rests not including the record/clamp spindle.
thanks
thanks
Just putting back together my gyrodec after international house move.
Bottom of bearing to platter rest: 53mm
Platter rest to lowest screw winding: 7mm
thanks you studiostevus.
would the bottom of the bearing be to the top of the plinth or from the very bottom including the base screw (underside of plinth)?
