Mic calibration
A 'from the beginning' calibration?
In the home theater forums, I have read many posts about DIY calibrations and most get it wrong.
Once again:
Before even thinking about doing a DIY mic calibration, read the Earthworks paper!
I guess the OP wants to know the transfer function of his microphone ("frequency response + sensitivity"). You don't need the Earthworks Big Bang method for that.
Once again:
Yes, you can recreate the Earthworks technique with a barbecue grill starter the maths for the response corrections are readily available on the web. You can get better than 1dB match to a B&K lab calibration. For sensitivity you can build a piston chamber with a small computer speaker and a slice of thick mailing tube and use a medical grade strain gauge pressure transducer in gauge mode to sample the internal pressure. They are laser trimmed to 1% (.1dB) absolute sensitivity and respond from DC to about 3500Hz. A small chamber gets around 300Hz resonance with a side benefit that because the resonant frequency is not geometric the harmonics of the excitation are rejected and you get the harmonic distortion of the mic. It's a fun experiment, you can get 150dB SPL internal to the chamber but back radiation of the speaker is not very loud.
I do have to say in general for DIY use the calibration problem is probably a bit overstated.
That's an interesting idea. Can you point me to a suitable pressure transducer that doesen't cost an arm and a leg?
