So this amp started with the issue that there was no sound, but thanks to llwhtt, I have solved that issue. I changed a zener diode (6.8V) and now there is 6.8V making it to the output IC(TDA7293) standby circuit, so that is awesome. Now the output IC is not stuck in standby.
New problem, now there is .3V AC making it to the output IC, 6.8V making it to standby, 44V DC to + power, -44V DC making it to -power, so that seems to be all good. When the output IC is NOT plugged in, I do not blow fuses. When the IC board (power module) is plugged in I blow a 3.15 slow blow fuse, and the IC chip burns out. I am lost at this point, and the worst part is I am afraid to turn the amp on if I "think" that I have found the problem because I will fry a $30 power module if I didn't actually find the issue.
Here are the schem's.
http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf
