Hello Tube Gurus,
can anybody help with schematic and Parts list
for the MFA MC Reference.
Can offer a schematic of MFA Luminescence for that. Don`t ask if you havn´t the above.
Reinhard
Reinhard
Hi, Reinhard
Pls check old issue Glass audio, it has this schematics (line amp only), it use 6DN7 and 6SN7(or 6SL7, I'm nor sure). It is a MFA Luminescence model A, it has 3 versions: A,B and C, they has a little bit not similar.
MC Reference and Luminescence
Hello,
the luminescense is an Bruce Moore design using oktal tubes throughout. The MC reference uses miniature tubes and when my information is right, it is a design of Arn Rothcap.
I have the issue of GA with the line amp.
Thanks,
Reinhard
Hello,
Thanks,
Reinhard
MFA MC REFERENCE PREAMP
I have in my system this absolutely fantastic preamplifier !
and good news for you i have the complete documentation !
i can make you a copy and send by postal way if you want.
Probably you can help me ... i replaced the 6922 tube in preamp by others 6922 but ..... in the power supply box there is a big rectifier tube called 9330 from penta laboratories ! impossible to find it , so is it the good reference ? no informations in the documentation .... all schema for preamp box but no details about the last tube i would like to replace .....
and internet site from pentalaboratories.com don't react .....from France ! ( you could try from another location ?)
picard.jeanlouis@free.fr
5930 is more likely.
An aviation rectifier, I had a number of them because on paper it was just the best my engineers could find and wanted to toy with it...Very expensive tube.
Cheers,😉
Cheers,😉
- Tubes / Valves
- MFA MC Reference
