MEMPHIS PR1X1000 repair questions
So I. Working on this amplifier again. I found that there was no shielding between the sink and outputs. Also, there was a rectifier with broken legs so I fixed them both after checking all the mosfets and outputs for shorts. All test OK. So when I started the amplifier, it started up, and protection light again.
So I removed the rectifiers to isolate the problem. Amp started up, bam a cap and diode shorted c39, d10 Co nected to a secondary winding on the transformer.
Or is it the vcc regulator or caps? Regulator reads a short. C32 is bad as well. Anyone know the value of c31
1
