Dear Veterans & Fellow Enthusiasts!
I have gained valuable clarification, refinement and augmentation in my amateurish understanding of loudspeaker design through your insights and experience shared here.
I still have a basic question due to my being quite a lay person in this field. Unfortunately, even extensive searching for this answer over the internet has failed me, hence i take resort to this forum.
I do understand that irrespective of the quoted thermal power handling of a driver, its mechanical (excursion limited) power handling becomes relevant/dominant when used in applications like open baffle as well as sealed enclosures where Vb is much > Vas.
Q.1: For a usual entry level 8" mid-bass driver (eg: Goldwood or GRS driver as sold by Parts-Express; where Fs=60 hz; Qts=0.9; Cms=0.4; Xmax=3 mm, Vas=25 litres), what can i take its "mechanical power handling" to be in free air (or open baffle) when fed with a signal at its Fs? I am looking toward a modest open baffle application.
Is there a formula or equation that can give such value for any mid-bass driver?
Q.2: Would this mechanical power handling be higher in an open baffle considering it is fed with music which is non-synthesised (i.e. only acoustic instruments used as in heavy orchestral and folk)? - [Note: i will be driving it direct and full-range.... without any crossover component, with only a high-pass for a tweeter.]
Q.3: Given the same driver above, how much increase in its mechanical power handling can i estimate if as an alternative, i mate it with a sealed enclosure (in an extreme case) with Vb 150 litres (i.e. Vas * 6)? Is there an equation that gives such a figure for a given Vb as relative to driver Cms-Qts & Vas, so that it may enable me to calculate MECHANICAL power handling of a woofer for a range of sealed enclosure sizes?
Could you please shed some light on this? It would greatly help me gain clarity into this issue. I eagerly look forward to your insight and guidance!
Thanks and regards!
Sujat
Thanks and regards!
Sujat
The very best way to find out is to model the driver in software.
Thanks fatmarley, i was really hoping there must be some guideline or indicative 'rule-of-thumb' that could be taken as a base though.
I agree with u.. what i am seeking may not be the best way, but probably a workable way that can be taken as a guideline.
