A quick sanity check is needed, if you'll be so kind
I've been using a Focusrite Clarett 2Pre to make measurements of single ended amplifiers - so far so good. I have a 300W, 8ohm dummy resistor and a simple, single-ended attenuator box to ensure the voltage at the interface inputs isn't too high.
However I've got a bridged amplifier I'd like to test, and just want to double-check my methodology. In addition, I'll need a new attenuator design.
My idea is to wire across the resistor and feed the output into one of the interface's balanced/differential inputs - either the microphone XLR input or the balanced TRS line input. I'll use the signal positive and signal negative, and leave the ground floating.
In cases where the output voltage would be too high, I plan on having a simple H-bridge attenuator, dropping the speaker output by 10dB before it reaches the interface.
Here's the master plan. Any problems/issues? Any "best practices" when it comes to measuring bridged amps in sound cards?
