McIntosh MI 200 amplifier
Busy restoring a pair of McIntosh MI 200 amplifiers for a client.
Does anyone perhaps have a chart of the expected voltages from the power supply and on the various electrodes of the tubes.
I am converting this to solid state rectification as the two power supplies are actually different. One is what I expected, had the 6 rectifier tubes plus 4 can type electrolytics but the other had only 5 rectifier tubes and they derived the negative bias voltage from the same winding as the input stage's.
The second chassis had no holes for the 4 large can electrolytics so I am welding up both chassis and will mount the transformer and choke in the same positions so that they will at least look the same.
Hope someone can help.
