Hello guys. I have a woofer with SPL of 90 (8 Ohms) and 98 (4 ohms). I designed a L-pad with R serial 4.7 Ohms and R parallel of 8 Ohms. I´ll attached the tweeter´s impedance measurements that I did. Is It all right???
I designed the Xover too. I decided to Xover in 2K5, ´cause the
frequency response of the woofer It´s not linear above this range.
Butterwoth or Bessel???
I believe Bessel. With Q=0.5, I have C=4.7uf and L=900uHy
Butterworth...Ummm. With Q=0.707, I have C=6.8uf and L=600uHy.
Any comments??? If I made something wrong, please let me now.
Thanks in advance.
Marcelo.
Pta: The att. is a Excel Sheet.
Thanks in advance.
Marcelo.
I also need help matching woofer and tweeter. both are scan speak and i am trying to build some loudpeakers for studio monitoring and mixing use.
I am therefore trying to achieve maximally flat frequency response. do these two match well? any help from anyone would be muchly appreciated. cheers
woofer - ScanSpeak 22W/8857T 8" Revelator Woofer, Aluminum Cone
tweeter https://www.madisound.com/store/product_info.php?cPath=45_229_324&products_id=8521
FRD Consortium tools guide
rgds, sreten.
undefinition (see FAQs)
Zaph|Audio
RJB Audio Projects
Speaker Design Works
HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs.
Humble Homemade Hifi
DIY Loudspeaker Projects Troels Gravesen
Quarter Wavelength Loudspeaker Design
The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs
Linkwitz Lab - Loudspeaker Design
Music and Design
rgds, sreten.
Zaph|Audio
RJB Audio Projects
Music and Design
