I imraneesa Member Joined 2016 2020-01-21 4:06 pm #1 2020-01-21 4:06 pm #1 Hi Can I use normal diode in place of P6KE91A in the above mentioned amp. It is connected across positive rail and ground. Attachments 20200121_120535.jpg 968.9 KB · Views: 69 P Perry Babin Member Joined 2003 bcae1.com 2020-01-21 4:38 pm #2 2020-01-21 4:38 pm #2 They are not the same. The 91A is a transient voltage suppressor, essentially a rugged Zener. You must log in or register to reply here.
