Marshall 8080-Channel select button problem
Hi there,
I have a Marshall Valvestate 80v - Model 8080.
The channel select button from Normal channel To Boost channel is sometimes jumping from one to another, it usualy happens when i play some time (Maybe heat problem ?). But it usualy happens from Clean to Boost as long as i can remember.
Here is an image of the amp and this button.
What can be the problem ?
Tommy
The switch contacts can be dirty, the solder under the switch can be cracked, the switch can be mechanically failing, there can be a problem with the power supply to that circuit. TR1, TR2 could be going leaky.
Thanks,
I gave the amp to a technician and he said that every thing is O.K. with this switch, but i don't think he is a good technician.
I already paid him and i have warranty so i'm hoping he know how to repair it.
I asked the question in order to know better and if it's necessary i'll ask him if he checked this options.
I already have regrets for not going to a well known technician.
Thanks for helping
Tommy
