Several months ago I built at least 5 different enclosure designs for the A5.2, including the Giraffes. Having been a big fan of Scott's Pensils and the like for years, I'd be remiss in not saying that if your floor space will allow, the FH lite is well worth a look as well.
I've build quite a few examples of every model in the FH family, and while none are as simple a build as an MLTL for the same driver, I do think they outperform them several ways.
Whichever design you choose, some suggestions:
- it should be considered mandatory to both countersink all of Mark's thick bezeled drivers - but not the new CHS70/Pluvia 7, or the lower priced and less refined CHN70 - , and to chamfer the rear side of driver cutout as deeply as material will allow.
- a decent grade plywood "Baltic birch" etc is worth every extra dollar / Euro spent
- the drivers will take quite a few hours to fully break- in, so assessment of damping fill levels should be made after the 200+ hr point. Yes, that does mean some temporary arrangement to seal one side ( or in the case of MLTLs, the backs) during this interim
