Hi everyone- this is my first post here, I hope I don't screw up by putting it in the wrong section or something...
So I found a pretty nice Marantz PM66SE receiver for $10 at Goodwill. It appears to be the European model based on the plug and 230v AC power requirement. It didn't power on when I got it, but somebody had already opened the case and removed the fuse so I replaced it with a matching one. When I plugged it into my Philmore step-up converter, it powered on for a second or two (and my lights flickered faintly), then went off. Upon further inspection, both times I tried this the fuse in the converter itself had blown but NOT in the receiver.
Now, the converter has a plug for 220v- I don't think the fact that the receiver needs 230v should matter, right? I thought there was usually some tolerance with those figures.
The power board inside seems to have solder pads, jumpers, etc. labeled for each region (EU, JP, US). How hard would it be to reroute some wires so that this thing would accept standard 110/120v from a US plug? There are unused pins on the back of the transformer inside, maybe rearranging there? The service manual didn't seem to help me...
FYI, I'm an amateur with electronics hacking, mostly based on retro game consoles but pretty confident in my abilities to mod something like this! Thank you for any help.
