Hi guys...I'm having major problems with the BPA200 LM3886-based parallel/bridging amplifier design
which are preventing me from completing my current project: My own chip amp-based multi-channel
hi power car amplifier.
It's almost complete, but I'm having major frustration with this "seemingly simple" servo circuit from AN-1192 Nat. Semi. app. note.
Specifically the servo circuit design example is causing major
headaches with the amplifier modules and power supply (as a result) when connected to the amp modules.
Here's what I have:
1. Noninverting PA100, tested fine alone
2. Inverted-mode PA100, tests fine alone
3. Together these form the BPA200, and work fine.
HOWEVER when I add my SERVO design example, I have terrible noise like "gritty popping" that is periodic and it causes my SMPS to overheat. Also happens when the op-amps are removed from their DIP sockets in the servo board.
I've breadboarded the servo design, which is modular and connects to my amplifier modules.
I've tried everything, checked my work 4 times, but no results.
Here are my questions:
1. Any suggestions or possible starting points to check? Also, does anyone have a schematic of their
own that they have working successfully? I've emailed tlmadsen but no reply.
2. I've noticed the op-amp buffered input circuit causes a "pop" on amplifier power-up. Anyone have a remedy
or suggestions to make that shut up?
Thanks so much an attached are some images of the servo "noise" waveform I see on an oscope, and also the board itself.
Help please!
[IMGHTTPDEAD]http://www.gwinnett-mobile.com/photos/100_0507.jpg[/IMGHTTPDEAD]
[IMGHTTPDEAD]http://www.gwinnett-mobile.com/photos/bpa200_servowaveform.jpg[/IMGHTTPDEAD]
Here's what I have:
Help please!
