when i plug my new pc (which is earthed) into my hifi system - i get a
terrible hum
this can be eliminated by unplugging my other devices
( tv dvd player etc ) from the hifi amp
the pc is connected via the the headphone o/p
to a line in on the amp(phono)
my other devices and the amplifier are double insulated
and have no mains earths
has anyone had the same experience - whats the best fix
thanks in advance for any info
polyal
stoke on trent
terrible hum
polyal
stoke on trent
hi
common problem, ground loops, here is a solution that will work
http://www.maplin.co.uk/Search.aspx?criteria=ground loop&source=15&SD=Y
dont forget to use screened leads
