Hi!
I'm a french owner of Magnepan 3.3 loudspeakers. I want to bi amp them with two Hafler P4000 (only balanced outpouts). I have only found magnepan XO Filters. They just have unbalanced inputs and outpouts.
Does someone knows a way to soluce my problem?😕
Thank You for your Help
Apogee solved this problem by using AD SSM-5141/2/3 setup to convert balanced to unbalanced, and then back.
I have MG-IIs, and built my own crossover into the amp.
Jocko
Jocko
Jocko,
If you listen to Ella or some other great jazz vocalist I would like to hear your rig.
Thatchmo
Thatchmo
What kind of tunes do you listen to and I don't do anchovies or pineapple on my pizza.
Lil'Ole Thatch
Lil'Ole Thatch
PINEAPPLE?
What kind of Italian hillbilly do you think I am? Actually, the Hills do like pineapple on theirs.........
Jocko
Jocko
bi-amping Magnepan 3.3
Hi I am also a frenchman, living now in Colorado.
I don't have the answer to your original question but I can share my experience with bi-amping the 3.3. (Actually since I used a subwoofer this is tri-amping).
I used a Marchand XM9 electronic crossover, a home-built Tripath amp for the high- and mids, an old Yamaha AX-590 for the woofer panel, and a a REL-Storm subwoofer for the infra-lows.
The difference was night and day, the Magnepan 3.3 became incredibly velvety, warm and dynamic without loosing the airy extension that only dipole true ribbons have.
The REL high-impedance input was connected to the output of the Yamaha amp. For some reason if I used a second home-built Tripath amps for the bass panel (instead of the Yamaha) the REL subwoofer did not work well - it might be because of the high-frequency switching in the Tripath amp.
This finished to convince me that passive crossovers completely destroy the bass-signal. The wonderfully pure bass of Triangle speakers is because they connect the woofer directly and only use a cross-over for the highs (and mids if there is a mids driver).
Of course their tweeter does not compare to a Magnepan...
I now suspect the wonderful Magnepans demos I heard at hi-fi shows in Paris were bi-amped.
My current search is to get similar quality with a thinner open panel or open baffle speaker.
- Magnepan 3.3 bi amp
